RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 12-22-2005 | 08:53 PM
  #3875
airstik2003
Default RE: U-Can-Do 3d 46?
Jack211
it will be a month before i fly my showtime but i would go with the do
also i'm putting in a magnum 120 4-stroke, i'm not sure what prop i will use,i
have 5 HS-5955TGS for all surfaces, for trottle i have a futaba 3001, because
of the large ounces of tork(333on. on 6v) from the servos i'm using 2 6v packs
on different switches pluged in to different ports on the rec., a polk seaker2 8
channel rec., a slimline fuel butten on the cowl, and remote glow starter plug
all i need is the remote glow, the magnum 120, and the rec.
so i can't check the cg
the only thing i'm changing is the tank
i'm lowering it
38
