RCU Forums - View Single Post - Low Down on the CMP P-40 40 size ??
Old 12-22-2005 | 11:11 PM
pocatosaras
Default RE: Low Down on the CMP P-40 40 size ??
I have three of the CMPro products but the P40 is not one of them. I have the 40 size Super Chipmunk, 40 Size Staudacher S-300D, and a 50 size Katana. Generally I've been pretty happy with the products and even more happy with the distributor I bought them from (www.jet-hobbies.com).
I built the Super Chipmunk already and had a problem with the landing gear that is wing mounted.
See this thread for more: http://www.rcuniverse.com/forum/m_34...tm.htm#3497302
Other than the LG, it's a nice plane and flys well with an OS 46FXi in it. Fairly simple to put together (took me about 40 hours). I crashed it the other day and it's in a bit of disrepair but I can get it flying again. I'd be careful about getting the Super Chipmunk until the manufacturer beefs up the wing area like I did on the thread. They are supposedly looking into doing this but it'll be a while before the improved version hits the marketplace.
I'm currently in mid-build with the Staudacher S-300D. I'm putting a Saito FA82a 4 stroke in it with JR servos and receiver. I replaced the stock rudder hardware and put in a pull-pull system. This plane is beautifully manufactured and I think it'd be a great choice over the SC. It's a pretty straight forward build and not too expensive. I can't wait to get her in the air.
The Katana 50 is still in the box but I've looked everything over and it looks as nice as the Staudacher.
Generally speaking I think you can't go wrong with CMPro products. They're manufactured nice and very affordable. The SC LG is a design flaw, which they're fixing -- not poor manufacturing. The distributor communicated this directly back to the manufacturer and they were pretty open to the criticism and I believe will fix the problem.
As for the instructions, I have found that they aren't that great for either plane I've built so far and I give them a C+. If you have any building experience at all though you shouldn't have any problem. Just read through carefully.
Good luck.
