RE: Bent Crank
brocja01, has the engine been involved in a crash, or has the prop hit a solid object while running at high revs ? If the answer is NO to both these questions , then it is highly unlikely that the shaft is bent , and you only have an shockingly out of balance prop. Get it balanced before starting the motor again.
