RE: Does your DA50 do this?
Well all I have to say is wow.... talk about power, what a major difference between the G26 Zenoah and the the DA50. But man is it noisy. Have the standard muffler in there, just sounds so sweet but noisy as hell.
Just finished one gallon the bench, another 4 to go. Just a quick question how much more till the black fudge goes, it seems to have dropped alittle at about 3/4 of a gallon on the breakin, but still plenty coming.
Using 32:1 oil mixing ratio a little rich on the H needle, turnign a 22x8 prop.
Also thinking about fitting the exhaust with a gasket or maybe use some high heat red gasket maker seal off the black fudge any comments on the subject ?
