AustinCraft (?) used to have one that was a U-shaped piece of aluminum. You attached double edge razor blades on either side of the U with short bolts. There was a short steel rod which inserted in the prop hole. Sit the rod down on the exposed edges of the razorblades and see which side of the prop would drop. I had one at one time. No idea where it is now.[
