RCU Forums - View Single Post - will a flex coupler work for a solid shaft?
Old 12-23-2005 | 11:04 PM
Ron Olson's Avatar
Ron Olson
Default RE: will a flex coupler work for a solid shaft?
For a solid shaft, you're better off using a universal joint type of setup. That will help with any minor misalignment between the engine and shaft.
I prefer the flex cable setup myself as that's what I'm used to but have had some boats (RTF type) that have used them. It's a cheap and easy way to build a mass-produced boat.
