RE: Help with Flatout Flatana
What is the discharge rate on the pack? if it's somewhere near 15 you should be perfectly fine. I just got a cheap charger for mine, ot does the trick. It's the Polycharge, I beleive it's 25 bucks on tower. Good luck with the plane, and hopefully you don't have problems with the hinges when you assemble it! If you do, the best tip I got was to heat the clips, with a lighter or anything you have that'll work. Hopefully it wont be a problem though!
