RCU Forums - View Single Post - will a flex coupler work for a solid shaft?
Old 12-24-2005 | 12:02 AM
Ron Olson's Avatar
Ron Olson
Default RE: will a flex coupler work for a solid shaft?
Not only does it make things easier to set up but you'll have more adjustability if you have to make changes in prop height and angle for best handling. Setting up a flex cable isn't that difficult but I'm used to it.
