RE: BVM Tires
I used the drill press method------once. THe red hot "T" pin method is much faster and easier. I have never missed lining up the hole with the 'T" pin. Make sure you use the large pins and not the small ones. Also there is no way you are going to screw up the threads like you can with the drill. Scott
