RCU Forums - View Single Post - Acceptable aileron hinge gap for a Trainer?
Old 12-25-2005 | 01:06 AM
Time Pilot's Avatar
Time Pilot
Default RE: Acceptable aileron hinge gap for a Trainer?
ORIGINAL: HighPlains
Cut into the aileron where it interferes with the torque rods. Knife and small round file makes it easy.
It's not the aileron that's the problem--the torque rod is sitting high. The only way I can reduce the gap is to build up the back of the wing a bit, around the torque rod.
This is my first balsa bird with ailerons, and I've learned an important lesson. Next time I will recess the Torque rod a bit. Didn't have the experience.
But what about the concern with the CA properly coating the hinges if I add a 1/16: strip where the aileron will fit onto the wing? Will the CA wick in properly, even if I drill a hole down the center of the hinge slot?
