RE: Acceptable aileron hinge gap for a Trainer?
Time Pilot,
If you haven't glued the ailerons on yet, applying a 1/16 strip to the wing hinge like is the perfect solution. Produces the same result as if you had recessed the torque rods that much. The CA will wick in fine. Adding the lamination doesn't change the characteristics of the slot.
Multiflyer
