RE: My beginner's plane - the Air Scout
More progress on the covering tonight....
Same sequence as the right fuselage side, cut the window holes first, removed the covering, added the clear "window" piece and cut to size. Re-tacked the side covering in place, attached to the fuselage by gently pulling and ironing away from the windows in all directions.
Extra piece of white covering between the windows is to cover up a tear in the covering when I was cutting the window holes. ooops!
