Spitfire Cowl
I have a Top Flite Spitfire I am in the process of building, my question is the 3 degrees of right thrust means that the spinner backplate sits on a angle so when I put the straight cowl on, it does not line up with the spinner backplate, how do I line it up without having the cowl mounted on an angle?
Have tried mounting it with the cowl on an angle but you can see that the cowl is on an angle and it looks weird.....
