ORIGINAL: krayzc-RCU
i put in my order for one it should be here this week. r most of you running pull pull on the rudder.
I plan to use jr 8101 on every surface with a YS-120
I'm using a Saito 150 with the servo in the tail. If you can, mount everything except the rudder servo and check the CG to see where it works the best. I am balanced about 1/4" behind the recommended CG, and I used the battery pack to balance.
Your motor is a few ounces heavier than the 110, so I think you will need to go with the servo in the tail.
Ken
