RE: fuel delivery problems
Hi!
You would be better off without that fueler...it's much better to run the fuel line direct to the carb and have a third line hanging down under the cowl to which you fill the tank. The second line is also hanging down undre the cowl and this is the overflow line. These lines are closed with a short 3mm screw as soon you have fueled the tank. Much simpler!
Regards!
Jan K
Sweden
