ORIGINAL: fastzilla
do these heads come fully neutral adjusted ??? and why on some the fly bar looks so short ??
Yes, neutral adjusted. Comes with a small rod to keep the linkages lined up while shipping/handling. When you get it, you take the short one out and install the standard length flybar that comes with the Blade on the plastic head. Once you do that, remember to center all of your servo's, reset your gyro and then install the CNC head. Hook up the linkages and then measure everything and use a pitch guage to set the proper pitch settings.
