RCU Forums - View Single Post - Old fuel, split it or chuck it?
Old 12-27-2005 | 10:44 AM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Old fuel, split it or chuck it?
Actually, unless the storage is above 97 degrees, the nitro stays behind. You will have nitro and oil remaining. If you knew you had a full gallon to begin with, you could replinish the missing methanol, and the fuel should be good. The oil should be good, the color ususally turns because sun or light exposure will eventually cause the dye to darken. You could try it on an engine on the bench to be sure.
