RCU Forums - View Single Post - 7CAP model memory slot 1 elevator problem
Old 12-27-2005 | 11:13 AM
airroy's Avatar
airroy
My Feedback: (7)
Default 7CAP model memory slot 1 elevator problem
Gentlemen,
I have a 7CAP transmitter just under a year old. I have noticed something strange with a single model memory slot and am curious if there is something I can do about it.
Model memory slot #1, servo #2 (elevator) has a problem with the end points. Any servo through any Rx that I connect to that position will not move fully in one direction. In other words, I can get a full CC movement but only about 80% CW movement even though I can set end point in the transmitter all the way the servo stops moving at about %80. If I simply use another memory slot for this model setup all is fine. Full movement of the elevator servo. Just not in mem slot #1.
Any suggestions are welcome.
Regards,
Airroy
