RCU Forums - View Single Post - ct4s belt problems **SOLVED**
Old 12-28-2005 | 08:02 AM
bmauney
Default RE: ct4s belt problems **SOLVED**
Interesting but I don't think I would recommend your modification if your racing or dragging it appear to add a lot more weight to your car then most people would want. I'm still using my acceleration kit and I'm using a smaller faster motor. My car is doing fine. Plus you need to take those rubber tires off and replace them with some foam tires. Those rubber tires will have you sliding all over the place.
HAy has anyone seen the new CT5 from CEN?
