RCU Forums - View Single Post - Engine Break In on a Nexstar
Old 12-28-2005 | 09:08 AM
rwright142's Avatar
rwright142
Default RE: Engine Break In on a Nexstar
ORIGINAL: swimman
I just purchased a Nexstar and read through all of the manuals. The Hobbico manual says nothing about breaking in the engine but the OS manual does and goes into detail how to do it. I'm very familiar with nitro engines used in ground vehicles and the importance of breaking them in properly.
What does everyone suggest to break in the OS 46? Should I follow the OS manual and run a tank through it on the ground at full throttle richening and leaning it out every ten seconds? I've never dealt with plane engines although I don't think they are much different than their ground based counterparts.
Thanks...
In the NexStar manual I received it said the engine was broken in at the factory. Double check your manual. If you do not see this (it may have changed since I bought my NexStar last year) then definitely follow the engine manufacturers break-in procedure. I may be wrong bit it wouldn't hurt to break-in the engine again.
