RCU Forums - View Single Post - Engine Break In on a Nexstar
Old 12-28-2005 | 09:23 AM
jagnweiner
Default RE: Engine Break In on a Nexstar
Although the engine is allegedly broken in, in my experience helping two others with their NexStars, the engine will work better if you run a tank through it on the ground, following OS break-in procedure. After that, you should be able to fine tune the high and low speed needles a little better. The low speed will likely need adjusting to get a really nice idle.
-Scott
