RE: durability of plane
That is a T 34 Mentor & yes the airframe is made of foam, as stated in the last post they will take some light abuse but they will brake fairly easy as well. The good news is that they are a quick fix with some foam safe CA glue & a squirt of activator. Make sure the CA you use is foam safe, if you don't it will melt it. Good luck.
Mark
