RE: Engine Break In on a Nexstar
What's the best way to break the engine in on the ground? I assume the engine is mounted in the plane with the prop installed. I've seen people use wing stakes (is that the term?) that are placed in the ground and then rest against the leading edge of the wing so the plane does not move when power is applied. As I've have never broken a plane engine in, any help is appreciated.
