RCU Forums - View Single Post - Advice on building a Tipo
Old 12-28-2005 | 03:25 PM
tipo750
Default RE: Advice on building a Tipo
There's a little downturn in the fuselage bottom near the rudder hingeline that will allow the fuse to scrape the ground without the stab touching. You could theoretically then build it in a taildragger configuration... although it wouldn't look right, it would be the only option if you wanted to do an inverted engine (with the exhaust running straight back).
