RCU Forums - View Single Post - Dual receiver experience,
Old 12-28-2005 | 03:28 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Dual receiver experience,
I have a DPSI Twin, and plan to run on 2 frequencies simultaneously. It is a big unit and not so easy to integrate into a smaller plane.
To me, running two receivers on the same channel is a solution looking for a problem. The_real_ problem is narrowband interferecence. In the presence of such interference, 2 receivers (on the same channel) with different antenna orientations helps a little (maybe), 2 receivers on 2 different channels helps a lot.
I have not flown it yet. AFAIK, there are no commerically available transmitters on the market in the US that will let you do this. This to me is just a stopgap until we get a more reliable long range spread spectrum ISM radio going.
Good luck,
