RCU Forums - View Single Post - Reverse rotation
Old 12-28-2005 | 07:04 PM
teddywilk
My Feedback: (10)
Default RE: Reverse rotation
IF U USE A CDI ON THE NREVERSE ENGINE U ONLY NEED TO MOVE THE PICKUP OVER 60 DEGREES AND IT SHOULD RUN REVERSE WITH OUT A PROBLEM. A FLY WHEEL MAG MAYBE A PROBLEM. I NEVER TRIED THIS BUT I THINK IF YOU TURN MAGNETIC COIL OVER AND MOUNT IT 60 DEGREES ON THE OTHER SIDE IT MAY WORK TOO BUT IT WILL BE A PROBLEM TO MOUNT THE COIL OVER THERE. U SHOULD GO THE THE CDI I THIONK IT WOULD BE SO MUCH EASIER!
FARMER TED
