RCU Forums - View Single Post - Bent Crank
Thread: Bent Crank
Old 12-28-2005 | 11:02 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Bent Crank
What model OS 15 do you have. Some of the cranks you cannot get anymore?
You have to take off the head & backplate, remove the cylinder sleeve to get the piston/rod out. Then you can get the crank out.
Will probably require heating in the over to 275 for 20 min for the sleeve to be loose enough to push up with a dowel
