RE: Brakes and Radio on FFMT2
Hi,
Well I've been looking and can see that there is obviously no hard'n'fast method. Do you guys find it better to have the spring on the throttle linkage before or after the servo arm? I've been scratching my head (till I got splinters under my nails!) and figure that the spring between the arm and carb gives a bit more "feel". But could this be disasterous if something let go? Would the spring then cause the throttle to be forced open? Hope this isn't too confusing. Thanks heaps for your patience.
Cheers,
CR
