RCU Forums - View Single Post - Hangar 9 Alpha??
Old 12-06-2002 | 08:06 AM
IMCub
Default The Alpha Works Fine
I'm learning on an Alpha. Fly's great! It doesn't do knife edges, takes a lot up down to keep the nose up when inverted, but I'm very happy with my choice.
What I've experienced:
1. Check all the servo's for binding - My throttle alignment was a disaster waiting to happen.
2. Check the noise wheel alignment.
3. Check all the control for alignment.
4. Tighten the bolts holding the nose gear on.
In all, the 1 hour setup took me nearly 6 hours because the control adjustment was manual (on the plane) vs electronic (in the radio).
5. Bring a couple of spare props when you get ready to land. 10x6 - two blade works great - don't forget a prop nut or 2 hole spinner. The three blades are relatively expensive and I like the 2 blade a lot better.
6. I was concerned about getting a newly designed motor, but it works great, starts easy, pulls strong.
7. An instructor is strongly recommended!
Now, were did I put those floats?
