RCU Forums - View Single Post - Spiraling slipstream & pattern aircraft design
Old 12-29-2005 | 08:00 AM
  #40
mesae's Avatar
mesae
Default RE: Spiraling slipstream & pattern aircraft design
ORIGINAL: stek79
Guys, I'm glad this thread is found interesting by many...
Thank you all! Tomsky, you did a great explaination, I never thought P-factor could yeld a 20% thrust difference!!! THANKS for that calcualtions!
I'm interested particularly in the slipstream issue, let's go deeper!
I agree. Correct me if I'm wrong, majortomski: Be careful using that 20% figure, stek79. I don't believe majortomski's analysis was intended to be detailed enough to quantify the difference under any particular set of conditions. Tom's analysis made several assumptions, including the CL of the prop airfoil and only considered the 9 and 3 O'clock positions (the points at which the resultant velocity difference is greatest), and only at the tips of the blades, and the effect of vortices was not considered. To meaningfully quantify the difference would also require analysis at several different stations. Every change in angle of attack, airspeed and prop RPM or pitch will result a change in the "center of thrust". Majortomski's analysis does splendidly prove that there is a significant difference however, which I believe was his intent.
