RE: OS fs-91 surpass running problems
It sounds like the engine is just too rich to accept the throttle. You need to get 15-20 minutes of running time on the engine at full throttle, and then start to lean it towards peak RPM. After about 40 minutes of running time, you should be able to lean the engine to the point where it's just rich of peak RPM. Then you can retard the throttle and start working on the idle mixture and RPM settings.
