RCU Forums - View Single Post - Is something wrong with my engine?
Old 12-30-2005 | 12:55 AM
BlackFox
Default RE: Is something wrong with my engine?
ORIGINAL: foxracing500r
Thats during break in you need the oil to lubracate the piston and sleeve during break in. Im not talking about that, He already broke his vehicle in. Hes after the fifth. Im not calling you stupid or nothing Im stating a fact
But you still need oil. If you run it lean, you will have less oil, and the engine will run hotter. Running hotter means more friction. Don't you need oil to reduce friction? You don't want the engine to run lean at all. It is better to be rich, than lean, but ideally, you still want to be just slightly rich. Don't forget that that piston in your engine is aluminum, and it doesn't take much to damage such a soft metal.
