RCU Forums - View Single Post - Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Old 12-30-2005 | 02:20 AM
  #55
Mcubed
Default RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Here are some more picks. As you can see I did a lot of work around the nose. The next one I build I will modify the whole fuse in line with the correct silhouette IE reduce the hight right through as the hump I now have at the cockpit is to high. I have had no trouble with the tale wheel but did reinforce it during the build. I always fly of a grass field!
Reducing the height of the fuse realy accentuates the fact that the upper wing is to high, I have not changed this on this model as it will require a major refit to fix. The markings on my plane reflect the real SE5A which resides in the Australian War Memorial in Canberra Australia, this is where i also got most of the nose detail.
Happy flying, any landing you dont have to take a bag to is a good landing.
ID:	377814   Click image for larger version
ID:	377815   Click image for larger version
