ORIGINAL: ptgarcia
[How's this combo working for you? I'll be using the same, with Thunder Power 2100mAh Pro-Lites. Is there anything I should pay special attention to?
I get 8-10 minute flight times depending on routine....but it has great climbout with the 13t pinion and the 325 pro-blades very little bog on full pitch to pitch maneuvers....i'm using the Apex 3s 2200mah packs...
just be sure the throttle channel is reversed on the radio if you have a Futaba....otherwise you could be replacing a main gear before the maiden flight
...also use the super soft start feature.....
Jack
