ORIGINAL: boostcrzy
ORIGINAL: ptgarcia
[How's this combo working for you? I'll be using the same, with Thunder Power 2100mAh Pro-Lites. Is there anything I should pay special attention to?
I get 8-10 minute flight times depending on routine....but it has great climbout with the 13t pinion and the 325 pro-blades very little bog on full pitch to pitch maneuvers....i'm using the Apex 3s 2200mah packs...
just be sure the throttle channel is reversed on the radio if you have a Futaba....otherwise you could be replacing a main gear before the maiden flight
...also use the super soft start feature.....
Jack
Thanks for the advise Jack. I'll be using my 9C so I'll have to be sure and reverse the throttle.
