RE: Advice on First Radio
The Futaba 9C sounds exactly what I'm looking for. Now for the next couple of questions. Whats the differance between FM and PCM modulation? Which is better? And will it interfere with other planes at the airfield or can the "channels" be changed or programmed to one with no one else on it? I know I didn't phrase it right but I know there are numbers at the airfield that you choose when you arrive that then are "yours" so no one else flys on them. Therefore you don't interfere with them or they with you.
Thanks again,
Flatfoot
