ORIGINAL: clguru
I was just hoping to find someone that has the same setup, so I could avoid potential guesswork.
Dan
Trying to find the same setup as yours and using it is guesswork.
Even if you find someone with the exact setup as yours chances are you will still have to move things around a bit to get the CG right. When you talk about same setup, you have to take into account servos used, building technique, paint, stock canopy or cockpit kit. Some people can build light and some build heavy.
