RCU Forums - View Single Post - Guillow's Spitfire Build
Old 12-31-2005 | 12:52 PM
combatpigg's Avatar
combatpigg
Default RE: Guillow's Spitfire Build
PHLIP, You're getting off to a good start! You might have already done it, but I think it pays to run some lines through the newly airfoiled wing on the side view drawing and check incidence, chances are you will need to recontour the wing saddle. Same goes for the stab and firewall, just to make sure that everything in the drawing is at zero-zero-zero.
