RE: Guillow's Spitfire Build
Yee ha! Let 'er rip dude! I've heard that making the wing semi-symmetrical makes for better flights! Before getting too far along you should do a draft layout for your tank, battery, receiver and servos as well. This will help you determine if you have enough clearances, if you need to trim formers, if you CG will be close, etc. I did some of this early on w/my Zero but not nearly enough...
eroc
