RCU Forums - View Single Post - "OFFICIAL"Redcat Racing TRUCK thread
Old 12-31-2005 | 11:17 PM
nitro-rc
Default RE: OFFICIAL Redcat Racing TRUCK thread
jboy the high speed should be 3 1/2 turns out from bottomes out the low speed should be flush and pull your filter off an you should only have a 1mm gap get your servo into the neturel postion and just turn the idle screw till you have that 1mm gapp remeber try this start the car agter you checked the high and low speed controls it will rev high at first then go to normal then just tweek the idle screw don't play with the transmitter idler it really does not help you will really get fustrated because it will always idle like crap and also when you run a couple tanks of fuel threw it you will notice it idles better and not so high
