RCU Forums - View Single Post - prop position
Old 01-01-2006 | 02:04 AM
TERBObob's Avatar
TERBObob
My Feedback: (21)
Default RE: prop position
Pusher looks more original .... pullers look like someone got things backwards ...
IMO - pushers run better since they are directing the thrust at the rear-most postion on the hull rather than more towards the center , and since you want the hull to plane as good as possible , then with the thrust being applied to the rearmost section of the hull , it is easier to set ( prop thrust angle ) and plane out .
