RCU Forums - View Single Post - 2 vs 4 stroke fuel
Old 01-01-2006 | 10:22 AM
Fuelman
Default RE: 2 vs 4 stroke fuel
I second what Hobbsy just said. What you are using is just fine for your engines. No need to get all worked up two stroke or four stroke fuels. If the oil content is being met or surpassed with what you are running and you are satisfied with the results, then you are fine. Everything else is just marketing.
