RE: SkiDoo Snowmobile (let the mods begin)
Kdubbs,
What esc are you running now? Also check to see if the track turms freely or if there is some binding somewhere. Check your brushes on the motor too.
I'm running a 12-2 trinity motor, 14 tooth pinion, with a Novak rooster ESC. I can run for about 20 min on a 3600 6 cell pack without even getting warm.
A tip for setting your gear mesh: Squish a pice of notebook paper between the two gears while you tighten the motor down. rotate the gears to get the paper out. they shoud have just a little slop and your good to go.
