RCU Forums - View Single Post - MY KADET LT-40 BUILD
Thread
01-01-2006 | 03:18 PM
178
shd3920
Aug 2007
1,610
Pittsfield, MA
RE: MY KADET LT-40 BUILD
RTW, as per plans the fin/rudder has two hinges and the stabilizer/elevator has 4.
Here is my latest update on my covering . . .
As you can see from my earlier post in this thread regarding the color scheme, I have been modifying the scheme as I go along to better improve its looks as I see fit: Instead of the front side fuselage being blue only to the front of the windows as originally planned I extended the blue on the sides to behind the wing saddle area. I have also modified the hatch a bit by adding the white stripe. I have also added white stripes to the fin and stabilizer and made the underside of the stabilizer blue instead of the whole thing being red as planned. I am going to add white stars to the underside of the stabilizer as I am doing with the underside of the wing. I am not using the gray window decals that came with the kit for 3 reasons, 1]acetone and such melts the paint on the decals, so what will fuel do? 2]I like black windows better and 3]the decals tend to get too many air bubbles underneath.
I am also going to change the color scheme on the fuselage in 2 ways, 1]instead of the top of the fuselage being red as designed, I am making it white to blend in with the sides and 2]instead of the bottom of the fuselage being all blue as planned, I am having it blue in front and white in the back to blend in with the side designs.
After the covering of the fuselage I will work on the hinges, permanent radio installation, and the engine/fuel tank permanent installation as well as the installation of the control horns and pushrods. Unfortunately I can not cover the wings right now as I do not have enough Coverite fabric so that will be on hold for awhile [
So here is the progress of my covering to date. The pics may add defects in the covering material that are not there in person so, if it does, please forgive.
Reply
Like
shd3920
View Public Profile
Send a private message to shd3920
Find More Posts by shd3920
View iTrader Profile
