RE: puppeteer
Hi Im new at this hobby too. I have also purchased a puppeteer mk2 kit as my first one and i think we could help each other out with our problems. I have build the fuselage c and im finishing of my bottom wings . be carefull when you will be doing the ailerons, and check if they fit correctly before you mount them. It would be best to put the engine in its place as soon as possible but go around forums and check for pictures so youll know what is going on. Do not put any servos and batteries in now. Do as much as you can on the model building , you will understand how it is done dont worry . Im only 15 but i understood everything after a while. People said to me that this is not a good for a begginer but i dont find much difficulties building it at all. Do not fly it as your first plane as you may crash it easily. Buy a cheap trainer for the begginning and let yourself understand how flying is done. Attend a local club and theyll help you out a lot, also remember that your local model shop is lead by an experienced moddeler who could help you out choosing the servos ,radio etc. at a later stage . Good luck with your model and send some pictures of your work in progress, i might send some of mine as well . Good luck.
Patryk!!!
