RCU Forums - View Single Post - Engine Break In on a Nexstar
Old 01-01-2006 | 06:11 PM
MikeG4936's Avatar
MikeG4936
Default RE: Engine Break In on a Nexstar
ORIGINAL: swimman
I assume the engine is mounted in the plane with the prop installed.
MAKE SURE the prop is installed! If it isn't, the engine will die within 10 seconds. (It would also be kinda hard to start without a prop ). I just used the OS manual instructions to break in my Nexstar. Good luck!
