RE: Aileron servos
If you run the servos on seperate channels, you will have two connections to make when you install or remove the wing. There is a danger that you will cross them. At best you will have to reinstall your wing.
With the Y-harness there is only one connection to make. No chance of hooking it up backwards.
enjoy,
Jim
