RCU Forums - View Single Post - Aileron servos
Old 01-02-2006 | 07:56 AM
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: Aileron servos
ORIGINAL: carrellh
Advantage to using two channels - you can use flaperons if you want
Disadvantage - takes longer to set up the controls because you have to set servo travel end points on two channels rather than one
If you can setup 2 servo ailerons using a y-harness, and without endpoint adjustment, you sure as heck can do the same with a two channel setup. Far too often people think that because the computer radio lets one do something, that they must do it. Spend the time getting the control right mechanically. Endpoint adjustments should be used as a last resort for small fine tuning or in case there's a mechanical issue that prevents using the full range of the servo. The only thing that I've found takes longer when setting up up two channel ailerons is to learn or remember how to do the radio programming.
