No reason why not?? I find epoxy a pain to work with (you know...mixing, stringy mess etc
) whereas alaphatic resins(sp?) (carpenters glue) is water soluable so can be wiped away leaving a clean job at the end of it all.
If you've read the manual already then give it a once over again, but with the plans. It's not a difficult build by any means, but as always, planning and thinking ahead will make life much easier.
