RCU Forums - View Single Post - Should I replace Batteries?
Old 01-02-2006 | 09:08 PM
multiflyer
Default RE: Should I replace Batteries?
Batteries for just about anything are readily available from most battery suppliers. Just check the ads in the magazines and do some calling around. The bigger issue for you to address is the change to narrow band design frequencies used today. Is your equipment compatible? If not, your plane could be interfered with and your transmitter could cause trouble for someone else. I recommend a call to Futaba service if there is any doubt?
Multiflyer
